Newbie Router
sxlalan
21 Apr 2005
Skipton, Yorkshire
Hi
I am looking to start my first real woodworking project and would like to get a cheap router to initially use mainly for rounding over and grooving.
I have about £90 to spend and have been considering the following
Ryobi - ERT1150V/T - Router & Table Combo Kit ERT1150V/T
Draper R850V
Does anyone have any knowledge of these or other suggestions? The advantage of the Ryobi is obviously that it comes with a table which would presumably be useful for edging.
Alan
cambournepete
29 Mar 2004
Rangiora, South Island, Aotearoa
The Draper is a clone of the the Trend T5 which is a clone of an old Elu.
I've got the Draper and I like it. it's fine for hand-held use. For £90 you might even get a fine adjuster for it as well.
RogerS
20 Feb 2004
In the eternally wet North
Alan
A thread on the Ryobi is here https://www.ukworkshop.co.uk/forums/viewtopic.php?t=4195&highlight=
Are you intending to use it handheld or in a router table? If predominantly handheld to begin with then my advice would be to go with the Draper and then investigate router tables at a later date.
If you want to get experiene with a Router and table then the Ryobi combo is a good starting point and excellent value.
iIf you are located anywhere near Worcestershire then you are very welcome to come and take a look at mine.
Neville Lawler
26 Oct 2004
Wigan
Hi
I have just replaced my Bosch P500 router, approximately 15+ years old with the new Bosch POF1100AE Router. So far excellent performance for hand held work, I have a large Makita mounted permantly in my table. This was purchased from B&Q, price only £65. It is extremely smooth on start up and you only need one spanner for changing cutters. It is fitted with variable speed and will accept 6 & 8mm cutters. I have never had any problems with any Bosch products unlike some other manufacturers.
Neville
sxlalan
21 Apr 2005
Skipton, Yorkshire
Thanks for the replies guys and thanks for the offer Roger but unfortunately I am in Yorkshire so it is a bit of a drive!
I plan to do a lot of rounding over and grooving on my first job. I am kind of assuming that this would be easier with some sort of table. I have an old cupboard that I could convert to a table though so purchasing a table may not be necessary.
I would like to add to my above mini-list a second-hand Trend T5 which has supposedly only been lightly used and would cost about £80.
Thanks again
Alan
sxlalan
21 Apr 2005
Skipton, Yorkshire
Wow thanks Neil, that's a good price. Is the height easy to adjust on these? Would you recommend the 1/4" 850W Trend over the 1/2" 1150W Ryobi?
Alan
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi Alan
Sorry I don't know anything about the Ryobi but I do know you won't go far wrong with the Trend.
I'm not sure whether the T5 comes with an 8mm collet but, if not, I would recommend you buy one. You can then standardise on 8mm instead of 1/4" which gives you about 60% more steel for the same money. :wink:
Neil
RogerS
20 Feb 2004
Alan...if you do a Google search you get this...
On 22 Mar 2004 02:37:15 -0800, in uk.d-i-y [email protected] (mike)
strung together this:
>It's 1/2" according to Baron Bros website:
>http://www.buyatool.co.uk/acatalog/Buyatool_Online_Shop_Routing_27.html
The website's wrong, the Ryobi ERT1150 is 1/4". I know this because,
as I mentioned before, I've got one.
SJW
A.C.S. Ltd.
Also I've got one, don't forget :twisted:
Having said all that it' still worth considering the Ryobi combo...rather than try and convert your cupboard at a later date. It IS a good starting point. When I saw your first post, my immediate reaction was that maybe I might offer you my Ryobi router/table combo...but then I realised that as the price of a new one is so low, I'd only get about £50 or so and to be honest, it's just too damn useful to have around at that price.
Derek...you just got one, what do you think? Would you go the same rout (ouch) again?
A
Anonymous
Guest
Hi roger.
yes i would recommend the ryobi combo it is an ideal piece of kit to launch you into the world of routing and for the price you can't really ask for anything more. I have also used the router hand held and i find it quite comfortable to use OK its no where near as good as the likes of your dewalt 625ek or the trend t9 but if you went down that route you are looking at paying £250 just for the router. So the ryobi gets my vote.
sxlalan
21 Apr 2005
Skipton, Yorkshire
Thanks for everyones advice on this. It looks like both the Trend and the Ryobi have their proponents so I should be OK either way. To sum up, it has come to a choice between the new Ryobi/Table combo and a second hand Trend T5/ second hand (or self made) Table combo. Both options would be around the £90 mark. (Just to update, the T5 is the step up from basic with the 1/4" and 8mm collet and the micro height adjuster.)
Looks like it's time to get a coin out and make a heads/tails type decision!
Thanks again
Alan
Alf
22 Oct 2003
Up the proverbial creek
FWIW (for what it's worth) I've been extremely impressed with the Trend. Coming from a powered router disliker you can consider that high praise indeed. :wink:
Cheers, Alf
A
Anonymous
Guest
Thanks again
Alan
Buy the T5. I use mine loads. It will be the rolls-royce to the two minis you are considering in my opinion
sxlalan
21 Apr 2005
Skipton, Yorkshire
Thanks all, looks like the Trend is hedging it...
Anyone know if the T5 will feet on the Nu Toll BT102 entry level table?
Alan
trevtheturner
26 Feb 2003
Herefordshire, UK.
Hi Neil,
I am considering getting a Trend T5 to use with a recently acquired Leigh D4 dovetail jig. I think I have read it right, but can you confirm for me please - if I buy the T5EB 1/4" from The Saw Centre then I can buy the 8mm collet as an accessory to use with it? (i.e. that the 8mm collet fits both T5s).
TIA.
Cheers,
Trev.
