MrA
I got bitten by the woodworking (by my limited standards) bug which started slowly and its gained momentum then I decided that if I was going to spend hours in my garage then it might as well be in improved surroundings. I had a sectional concrete garage with a cement corrugated roof that leaked like a ba**ard with a concrete floor that was badly pitted and it was bloody freezing in winter and condensated (sic) like the Amazon rain forest.
I had several options;
1. Tear it down and build a brick garage lined on the inside with a flat or pitched roof.
Discounted due to lack of shekels available.
2. Resin floor with new roof and reseal the walls.
Roof replacement was expensive if I wanted it insulated and waterproof.
3. Resin floor, reseal walls line with OSB and over-clad corrugated roof with insulation and box profile roof sheets.
Bingo, could do most of it myself at a reduced cost.
Here are the results, constructive criticism would be appreciated and any advice on painting the OSB walls.
