Russell_AH
Hi everyone,
I'm looking to build a desk for my new room, and I'd like to get your opinion on the design before I go ahead and start buying/cutting etc.
The desk is to go along an entire wall of the room (approx 4.5m) and will be ~90cm deep (there is a sloping ceiling above the desk, so some of the space at the back will be unusable). I don't plan to have anything massively heavy on the desk, just a laptop, desktop (although the base unit will likely go on the floor), electronics and Lego .
I'm looking to make it modular because a) I'm renting, so at some point it will probably need to be moved and b) it's a loft conversion with a rather narrow 180 degree staircase.
The design will consists of 5 sets of legs supporting 4 spans of desk top.
The legs are constructed from solid timber glued and pocket screwed together (the large circles show roughly where the pocket screws will go). The dowels in the centre at the top will slot into the cross beams (visible in the 'bottom' picture). The small holes on the top surface will take dowels to hold the desk surface in place. I am considering using metal dowels and cam locks (as in Ikea furniture) to make it more secure instead of the dowels. You can see how the top will fit on in the "top" picture, and allow adjacent spans to sit on the same set of legs. The dimensions are approximate at this stage.
My main questions are regarding the choice of wood.
For the legs and cross beam, I'm considering 70mm x 20.5mm redwood from B&Q. I guess it will be easier for me to use the same type of wood throughout. Would this thickness be suitable? I think the 70mm width looks good aesthetically to me, although in the model I've used 24mm thick wood, not the 20.5mm think I'm planning on using.
For the top, I was thinking of 18mm plywood; is this a suitable material/thickness? Also, would hard- or softwood be better for this application? Are there any others you would suggest I look at? I am likely to paint the top black, would there be any need for any sort of edging?
Also, I'd like to ask about the supports:
Do you think the dowel joints would be enough to support the top, bearing in mind that this joint won't be glued to allow it to be easily dismantled? Should I think about gluing some sort of ledge/shoulder to the central supports of the legs to provide more support? Should I also think about adding a second or third cross beam? I'd like to not add one towards the front of the desk if i can help it to reduce the chance of me knocking my legs on it.
Finally, are there any thoughts on any other trouble I may run into? Regarding tools, I can see I would need a drill, pocket hole jig, clamps and mitre saw (or similar) to construct the legs/beams, plus a circular saw and straight edge to cut the top surface (although I may get that done at the store), plus a sander for finishing; is there anything else you think I'll need?
Thanks in advance .
Thanks in advance .
