New sliding mitre saw cutting off square
OldWood
1 Mar 2005
Edinburgh
Having recently used my brother's professional grade sliding saw, I decided to take the plunge and buy a Ferrex badged one from Aldis.
Today was the first time I have used this to cut a couple wider boards - that is 200mm (I see in fact it can cut up to 350mm) and found that this greater width that it's not cutting sqare - by some 4 mm in 200. OK - find the instruction manual and tune it up. But there doesn't seem to be any way to reset the turntable to give an accurate 90 deg cut across a board; the instructions appear to address setting mitre angles, blade vertical angle and likes, but not cross the table accuracy.
Has anyone got one of these ? Am I missing something, but try as I might I cannot see anything in the instructions to resolve this. Interestingly I see at the back of the instruction book that Sheppach's website is given.
Rob
wsb1207
25 Jan 2020
Norwich
Don't have one of those but on mitre saws it's generally the fence that's adjustable not the turntable.
OldWood
1 Mar 2005
Edinburgh
Oops - that is just a bit too obvious isn't it :oops: :oops:
So many thanks, and having slackened off the appropriate allen screws and discovered that the fence is slotted for this very purpose, I'm now lookng forward to giving my 30 years professional woodworker brother a hard time for not knowing that. :D :D
Droogs
Is that chisel shar ... Ow
14 Mar 2013
Edinburgh
maybe he does and just doesn't like you :twisted: :twisted:
Phil Pascoe
29 Jan 2012
The 90 degree pointer is usually adjustable as well.
OldWood
1 Mar 2005
Edinburgh
Actually it was your gravitational problem I'm going to challenge - what you are failing to take into account is that the smaller the item is, the less air resistance it has and correspondingly the faster it falls :roll: :roll:
And as far as my brother is concerne, 'being Petered' on the phone is a well known family catch phrase!
13 Jul 2015
Suffolk
Another common problem with sliding saws is that the further you extend the blade/handle along the rail, the less support it has, and any slight sidways pressure you apply can add very noticeable affects.
It's very common, even on the very expensive saws. The only one I am aware of that gets away with it, is the Festool Kapex at a lovely £1150 :shock: :shock:
