Hi Devonwoody
Could you stick the pattern to the wood, then saw it roughly to shape, then use a hole cutter, spokeshave or similar to remove a little more waste, then use a drum sander to finish it off? Possibly stack pieces if you wanted similar shapes. If it's for a pattern, would a piece of acrylic clear plastic be any good to use as it's see through?
Gary
