devonwoody
quoted only the relevant parts
The caller continues - 'I will be starting a Fraud Investigation. If you have any questions, you should call the 1- 800 number listed on the back of your card (1-800-VISA) and ask for Security. You will need to refer to this Control Number. The caller then gives you a 6 digit number. 'Do you need me to read it again?'
Here's the IMPORTANT part on how the scam works - The caller then says, 'I need to verify you are in possession of your card'. He'll ask you to 'turn your card over and look for some numbers'. There are 7 numbers; the first 4 are part of your card number, the last 3 are the Security Numbers that verify you are the possessor of the card. These are the numbers you sometimes use to make Internet purchases to prove you have the card. The caller will ask you to read the last 3 numbers to him. After you tell the caller the 3 numbers, he'll say, 'That is correct, I just needed to verify that the card has not been lost or stolen, and that you still have your card. Do you have any other questions?'
After you say no, the caller then thanks you and states, 'Don't hesitate to call back if you do', and hangs up. You actually say very little, and they never ask for or tell you the card number they already have it.
It is only a precise of the scam but if you want I can post the whole conversation but it follows the usual pattern but the three digit request is new to me. It enables the fraudster to then order immediately on line items with that new info. and does so quickly even if you ring back your credit card office.
