Negative rake saw blades
stage1v8
4 May 2010
Yorkshire & London
Hi Folks,
Thanks to a very generous person I am now the owner of a radial arm saw. Its in relativley good nick and seems to be reasonably accurate but the blade has a few chipped teeth.
It takes a 8.25" (210mm) negative rake blade.
Can anyone recomend somewhere to purchase such things?
J
Machine mart sell trends range of craft pro blades which you should be able to get locally. Normally I wouldn't recommend MM as they are generally expensive but the prices of these blades are good. I had one before I went the the Freud gold but it's three times the price and not three times better.
Will the machine take a 216 diameter?
thats a much more common size.
what bore do you need?
what material do you want to cut and what finish are you expecting.....
all these depend on the blade to be recommended
Well worth buying the best quality blade you can get J. Cutting solutions knows his stuff, a lot of the trade lads buy off him
Hi Guys,
Not sure, will have to check the clearance.
16mm by the looks of it but the current one has a spacer.
Mainly softwood and the best finish I can get!
I have had a dig round on the internet and there seems to be plenty of blades out there in the 210-216mm range but very few with negative rake teeth which seems to be the norm on a RAS.
The trend one looks good and seems to have a -5 degree rake so might be a winner.
J
Check that its not 5/8" rather than 16mm they are quite close.
What saw is it 8" is quite small for a RAS
Wealden do a 210 negative rake.
Jason
Ahem
I wouldnt have said if......
I could supply 216 Z=48 which will give you very good finish on all materials.
Top quality German blade
£22.50
+ post
+ VAT
Need to know if its 16 mm or 5/8" bore
Doug
