Hi,
Without re-opening (I've seen the previous posts!) the can of worms that is 'sharpening', do you sharpen/hone mortise chisels using the same method you would for bevel edged chisels i.e. at 25deg then 30deg for the micro bevel?
Cheers,
Jonny
P.S. If you're interested, I'm going down the hand sharpening/honing route for no other reason than I can't justify spending any more £££s on tools/jigs/rigs as I just want to get started on some projects so will mainly be buying wood!! (hammer)
Cheers,
Jonny
