woof
One of my major upcoming projects for 2009 will be a dining table with 100mm legs. To provide the frame/skirting, I was planning to use 54 x 75mm. See below for an initial sketch - but could change of course!
The frame will be made by morticing the 54x75mm into the legs but here's my dilemma. I have a Leigh FMT and just love the control using it to make perfect mortice/tenons. However maximum size I could make is 1/2" x 2" - and if I get a new upcutting bit, could make the mortice 2" deep. Would this be sufficient? Reading around I get the idea that the tenon should be 1/3 width, but the skirting will only be 2" (54mm) wide into the leg? If this is OK, then all I need is to get the special longer Leigh 180cl bit (or a similar I have seen on Wealdentools). If it won't be sufficient, then will need to consider getting a morticer and learn what you professionals do! Thanks in advance for your opinions and advice.
[/img]
[/img]
