Hi Noddy - yes, a bench stop (above) is also a very good thing, easy as a part of the build. I note BBs is at far right, do we have a left-hander here? If right handed, I'd put it over left, near front, to right of face vice, hence allowing long pieces support along bench top.
Still very pro the round 19mm... 20mm deletes the option of using all the commercially available 3/4 accessories. And note the round dogs have flats on them - not quite the contact area of the square but close. If you use wood dogs, just cut a flat on the contact face say top to 1". down. Some go to the slight bother of facing the dogs with leather - very good indeed as it grips limpet-like and reduces marring (use about 2mm thick, sheepskin is no good, cowhide too thick unless split, pigskin perfect, offcuts from a craft place, peanuts).
And if you ever try holdfasts you will be converted I am sure... unless you drill 20mm holes in which case, not so good (might just work but depends on top thickness)..
Before committing, if you want to come over and play with 3/4" complete with dogs, holdfasts, a bench stop etc, pm me and pop over.
p.s. Axminster ali dogs £13 a pair. I know shop-made hardwood is cheaper but these are lifetime basics I reckon:
http://www.axminster.co.uk/axminster-ax ... prod21296/
