MDF veneered shelf with contrasting lipping?
Darren D
17 Jun 2005
Nottingham
I'm very much at the beginners end of the talent spectrum and would like to run an idea by you before I get myself into trouble. I want to make some simple built in bookcases from 18mm maple veneered mdf. To add some interest, I was planning to make the face frame in walnut as a contrast - I've seen this combination a few times and liked it. I visited my local woodyard yesterday and they don't stock walnut but do have sapele instead - in it's rough sawn state it certainly looks like a nice dark wood but it is difficult to visualise the finished piece. I realise this is down to personal opinion but would maple and sapele make a nice combination? I'm happy to hear negative thoughts now as I haven't splashed out yet.
The second issue is less subjective. The bookcase will be around 300mm deep and 800mm tall and we intend to put a TV on the top. To keep costs down I was planning to use veneered mdf for the top of the bookcase too and then lip it with hard wood. I quite like the idea of using contrasting wood for the lipping as well. Is this a bad idea - I'm worried that there will be a very clear line in full view and so any inaccuracies in my work will be plainly visible. Any thoughts?
Darren
Freetochat
14 Feb 2005
Suffolk, UK
As to how the finish would be - I would get and offcut of sapele and make up a sample to see if 'you' like it.
The TV part I think needs more info. If you are going to use 18mm, I would be concerned with sag in the top shelf which would be very noticeable as a view point. This all depends on TV weight/size, and how the shelf is to be strengthened.
This something I am looking at. Was round the electrical retailers measuring TV's and getting weights at the weekend.
Scrit
17 Sep 2002
Hi Darren
Taste is very mush a subjectivething, but I will say that in the Art Deco/machine modern period (late 1920s to early 1940s and a favourite of mine) maple was often combined with either walnut or mahogany/sapele, so its not such an unusual combination. You might consider staining the sapele with a mahogany stain to bring-up the colour and lustre of the wood (and increase the contrast). If you can get hold of a copy from the local library I'd suggest borrowing Herbert Edlin's "What Wood is That?" which has a set of 50 or so actual veneer samples at the front (including maple and sapele). The publisher, Stobart-Davies (
http://www.stobartdavies.com/system/index.html), used to sell these sample kits on their own (without the book) at one time and they are a very useful accoutriment (the book is still available at £18.95). You can also get sapele hot-melt veneer edgebanding from mmany DIY shops to experiment with (staining, etc)
As to lipping in a contrasting wood I see no problem, although personally (and not having seen the design) I'd probably use the same material as your face frame. The best way to deal with a lipping is probably to treat it as a thick edge banding and trim it off with a guide-bearing template bit, then you won't need to worry about inaccuracies so much. One point I will mention is that MDF is not a particularly rigid material and will tend to sag if used in shelves longer than about 550/600mm. If carrying the extra weight of a TV you might like to give this some consideration.
Good luck!
Scrit
Darren D
17 Jun 2005
Nottingham
Thanks Scrit, nice reply. I quite like art deco stuff so if it was good enough for them, that's very reassuring. Nice tip about experimenting with the banding too - sadly I don't have an offcuts box to speak of and was wondering how to get some scraps to play with.
Freetochat - I've had a play with this fantastic Sagulator that someone posted recently and think that if I have a solid top to my bookcase carcass, plus another piece of mdf on top of that, it will hide all the joins between bookcases and give me a 36mm thick surface which, if the sagulator is to be trusted will work out fine (I'm allowing 30kg for the TV).
Adam
10 Sep 2003
UK
Darren D":27ecu5vt said:
Thats excellent! I;n a big fan of contrasting timbers and don't think you will have any problems with the maple and walnut
Adam
Darren D
17 Jun 2005
Nottingham
Well would you believe it, a quick check on the web and a pop to my local library and I now have a copy of this book in front of me. The samples are great and actually I'm in two minds now. The sapele is redder than I expected and I much prefer the walnut. I might look a little harder into sourcing that instead.
