nev
Evening all,
I'm having a bash at scooter number 2, a Lambretta, and this time its my own attempt at a plan and it just might work
Heres the first mock up...
Making the wheels is proving a little frustrating, I'm just no good at cutting circles :evil: , I know its just down to patience and practice but just when I think I've got the hang of it the blade decides it'd rather go somewhere else and that somewhere else is usually on the side of the piece I want to keep #-o
The front wheel above was made by drilling a series of 6mm holes around a hub sized circle then cut out on the SSaw, and fitted within the tyre but as you can see the gods of accuracy were not present.
On the Vespa I used shop bought ones sliced and glued and they work well, but before I splash out another 8 quid does anyone have any suggestions as to a cunning way of creating a facsimile of a Lambretta wheel and tyre :duno:
They will be walnut tyres with oak hubs/rims, approx. 43mm dia. 12mm thick and look like this in real life...
Lathe is still in boxes under bench, so scroll saw, bandsaw, wobbly pillar drill or neanderthal hand tools are available weapons.
Suggestions on a postcard please
