Benchwayze
Hi folks,
Following the forum links, I had a look at the method of making a tongue and grooved door, using stub-tenons. For simple ‘joinery’, in a workshop for instance, that would be okay.
For a stronger joint, I would use a bridle joint. With narrower stiles and rails, a long series router bit would cut a deep enough ‘groove’ in the ends of the stiles. If you don’t have a long bit, it’s okay to have a tenon, that isn’t quite full width, within reason.
Tip… To centre a groove, using the router table:
Choose a cutter, which is the same size as the panel thickness.
Adjust the fence, so the router will cut a groove slightly off-centre, (Easy by eye) working from the face-side first on all pieces.
Reverse the workpieces and run them over the cutter again.
This will give you a centred groove in each piece, that will allow a panel to ‘float’, without the need to mark the stiles and rails.
Don't off-set the first cut by too much, as obviously, the 'margin' will be doubled when you reverse the timber.
Hang your rule on a cup-hook!
I thought his might help.
