I needed a slim screw jack for a specific setup on the mill so I turned this one -
The base diameter is 25mm and the height is adjustable from approx 50 - 125mm, with the two spacers.
The only "novel" thing about this design is the use of a commercial spherical bearing to support the top so that it could be used at a moderate range of angles and be tightened up very easily - see photo below.
An outline schematic:-
![Screw Jack.jpg Screw Jack.jpg](https://cdn.imagearchive.com/ukworkshop/data/attachments/141/141955-d8f12d271290ac5aeabd52eebf49118c.jpg)
Fully dimensioned drawing available on request..... if anyone's interested!
Clive
![Screw jack A.jpg Screw jack A.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/141/141953-Screw-jack-A.jpg)
![Screw jack B.jpg Screw jack B.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/141/141954-Screw-jack-B.jpg)
Clive
