Dee J
So I need a 5.4m long beam for a sunroom/conservatory project. It is to be supported .6m from each end, and it will in turn support a lightweight flat roof. I've got about 300mm height to fit it into. Options - solid timber: heavy, a bit of a lottery to get a straight length. Commercial lattice joist - good, but the costs of a one-off are outside the budget. Could step away from timber and use a scaffold lattice beam or ladder beam- possible, but the 300mm dimension would be difficult to meet. Or I could fabricate a box beam - ply skins screwed/glued onto cls top and bottom rails. Light, cheap, strong - but assembling it straight and true would be the challenge. I don't have a flat work area that big! Ideas please.
