I've decided to mark each of my tools, partially so that I don't have to periodically scribble my name in permanent marker on anything I take to work, partially because I feel the need to assert my ownership over the array of second hand tools I seem to be aquiring...
Having ruled out interchangable type as unduly expensive, I had a go at one of my home made planes... turns out it's rather difficult to get all the letters lined up by eye.
So does anyone have a suggested methods of lining up punches, i'm thinking of creating a jig by morticing an offcut so that it's held square, and with at least one edge parallel to register the punch to a straightedge... Is there a a
simpler solution or handheld technique that i'm missing?
Secondly, Whilst i'm confident I can mark brass saw-backs and tools with a flat wooden surface; how to mark my chisels is puzzling me. Marking the upper portion of the blade will (i presume) require a hell of a whack, if the punch is even hard enough that is, but marking the handles poses a risk of both the punch glancing and in the case of my work set, the plastic shattering when exposed to such a concentrated impact.
Any suggestions/experience thankfully accepted.
