Leigh jig max timber size
KeithS
14 Nov 2009
East Lothian,Scotland
Hi all
I need to make a few boxes 400mm square, but the thickness of the timber is 28mm, (all four sides) can a leigh jig cope with this thickness.
Many thanks
Keith
You can do through dovetails in boards upto 1 1/4" (32mm) using the No 150 or 160 DT bits and the No 100 straight one, you will also need the larger dia 5/8 bush.
And a hefty router helps.
Jason
Hi
Thanks Jason, will be using a elu 177( this just will not die).
Anyone recomend the best place to buy a jig from and extra cutters and
bush.
Keith
Shop around for the jig
For bits and the bush I have used Handytools in the past, suggested by Brimarc the importers
Jason
