Kity 613 bandsaw tyre
Fatchef
21 Oct 2017
Nottingham
Hi all,
I hope that someone will be able to help.... I have taken a chunk out of the lower tyre on my Kity 613 bandsaw. Does anyone know where I can buy a replacement in the UK. The damage is to the leading edge and is about 100mm x 2mm. would carrying on using it while awaiting a replacement do any damage to the machine.
Thanks for any help I may get
it shouldn't do any damage to carry on using it. When you do, it may be unbalanced and vibrate. If that is the case, I wouldn't continue to use it because doing so long term may damage the bearings. If it is not vibrating, then I wouldn't bother to replace it.
Welcome fatchef. I wouldn't think 2mm from the edge would make much difference. I imagine the blade is further back from the damage, so shouldn't affect things.
