Obi Wan Kenobi
- Joined
- 27 Jun 2017
- Messages
- 148
- Reaction score
- 0
I recently purchased a s/h Kity 439 p/t . It came with a stand and apart from a very small amount of corrosion on the blade that was exposed, it was spotless. It had obviously had little use and even had the original price sticker on it! I was mindful that the 439 is discontinued and spares are few and far between, but I'd seen pretty decent reviews about it.
Everything appears fine - the motor is quiet, everything turns, moves and works as it should, and it cuts well (although the blades could do with a sharpen). Having said that, I'd like some advice on:
1 - I have noticed that when aligning the infeed and outfeed tables, there is a very small area on the outfeed table (very close to the rhs of the cutter)that is out of true when a straight edge is on it. It's very small but enough to let the light under a straight edge.
Obviously the table should be completely flat so I was considering either taking it off and getting it machined at a metal shop or having a go myself using the same method as flattening a plane iron. (I'll try to get a pic posted)
2 - There is no extension on the outfeed side of the thicknesser, so in order to support the timber is there anything that can be rigged up to the p/t to use as a outfeed table? If not I can probably rig up something, but no sense in reinventing the wheel :wink:
The first point concerns me the most as that will be key to accurate planning, but I hope that I haven't wasted my money on this p/t. Any advice will be gratefully received.
Obi Wan ccasion5:
Obi Wan ccasion5:
