Can anybody help?
I have removed the extension table from my saw and have put the shorter extrusions onto the saw. These were bought from somebody on the forum (who had no idea whether they were right/wrong etc. I am not looking to go in that direction).
1 profile has a scale on it- and is obviously the one that the fence runs along.
the second is different to the first and I have just realised that it is the same profile as the fence is made from- was this correct. If not, it doesn't matter that I can see.
In the fence profile, whether as above or as the fence, do the shape of the extrusions have any purpose. There are several channels that look like they should.
Finally a problem. When I align the fence with a handy mitre slot, it is all nice and parallel, from top to bottom. When I tighten it, however, I can see the far end move out of parallel about 2mm and see the difference on the mitre slot.
The picture isnt great, but the end moves from left to right. I cannot see how to stop it, or anything obvious that is pulling it out of square. I should have taken a picture of the underside- it is tightened by a plastic washer with a metal centre- on the extrusion, where I have tightened it a couple of times- this suggests that when it is fully nipped up, the metal is making contact. The kity long fence that I have has an all metal washer and fixing combined. It does the same, ie pull it out of parallel, but if you hold the end as you tighten, it will stay where you want it.
Any ideas? Has anybody had anything similar happen? I am using a short fence from a ts200, but the profiles are identical.
Mark
Mark
