Grahamshed":3o4l1fn0 said:
Thats what I was thinking guys but it is as well to ask
This riding the bevel malarky sounds dead easy but judging by the ridges I often get I am not very good at it yet.
Graham,
The ridges WILL disappear but it all depends on which tool you are using for which job and how you are using it!
I have made several hundreds of bowls, dishes and platters over the past 22 years and whenever the situation arises where the bevel is causing the ridges to appear, I change the tool.
I have several gouges of different sizes, diameters etc. that have a second bevel so that I can continue to use my favourite 1/2" bowl gouge size even on small diameter items and not get the ridge effect.
This is not a lecture, but persevere, as and when finances permit purchase more gouges etc. and grind them to suit. The old adage is so very true, I still do it myself,
practice, practice, practice.
Warmest regards, Peter.
PS! I forgot, keeping the burr as has been pointed out is wonderful for the first few contacts with the wood, then, dependent on the wood being turned, it usually disappears fairly quickly. I have always stropped the burr away after grinding scrapers etc, I turn the gouges upside down and hone the inside of the flute immediately after sharpening for the same reasons.
