Hi,
I had a quick search on the forums for an answer to this but surprisingly couldn't find anything (must not have been searching for the right phrase). Basically I'm looking into helping a colleague at work make a bird cage based around a wooden frame for some small parrots as in the picture below:
http://1.bp.blogspot.com/-Qyyj80DNPws/T ... mighty.jpg
I was wondering if anybody had any suggestions as to how you would make the joins at the angled sections along the top and bottom, preferably utilising a stronger joint than just a standard mitre. As well as this how would you then go about joining the vertical sections to these points (I'm thinking some sort of mortice and tenon but imagine it would get a bit tricky dealing with all the angles).
Hopefully you can work out what I'm asking, not sure I've done the best job of explaining it! Thanks in advance for any help.
