mtt.tr
Sorry for starting yet another jap related issue but why cant you dry grind them i haven't but want to know why i cant.
PeterSk":eqd970an said:Because pennies to pounds says that you'll overheat the edge and draw the temper of the steel
I seem to recollect Derek, in a previous conversation, that you mentioned that Jap paring chisels should have a single flat bevel at 25deg. This is so they can register from both sides (which is very useful btw) In any event, I don't grind my Jap chisels but use the full range of 3M papers from Matthew to hone a single bevel on my bench (30deg) and parers (25deg) chisels.I also hollow grind all my Japanese chisels ...
Regards from Perth
Derek
Agreed Derek... that makes sense. Doing it that way would make the honing process faster but I find that single flat bevel doesn't take too long to hone either. As ever, horses for wotsits :lol: - RobI seem to recollect Derek, in a previous conversation, that you mentioned that Jap paring chisels should have a single flat bevel at 25deg. This is so they can register from both sides (which is very useful btw)
Hi Rob
That is substantially correct. My argument is that chisels have a coplanar face. That is, they are not sharpened with a secondary bevel. The presence of a secondary bevel makes it impossible for the chisel to register and be used bevel down (as one does when either paring in a close area or when attempting to limit the cutting action). A hollow grind offers the same registration advantages as a flat bevel as long as the microbevel is honed on the bevel face, that is, at the same angle as the hollow. Of course a hollow grind has advantages over a flat grind when it comes to sharpening.
25 degrees for paring chisels
30 degrees for chopping chisels
Regards from Perth
Derek
mtt.tr":2pmhgk6w said:So if im careful on a dry high speed grinder i shouldn't have an issue same as my other tools
GazPal":33zimudr said:mtt.tr":33zimudr said:So if im careful on a dry high speed grinder i shouldn't have an issue same as my other tools
Just be sure to keep quenching the blades to keep them cool and all should be well. Or you could invest in a wet stone grinder.
mtt.tr":1twidonj said:GazPal":1twidonj said:mtt.tr":1twidonj said:So if im careful on a dry high speed grinder i shouldn't have an issue same as my other tools
I just work out why i can grind all my other chisels but not these well im sure all will be fine
