kevinr
I need to build a cupboard or two to fit an odd sized space. Probably pine frames filled with T&G - nothing too fancy and maybe some veneered MDF for the interior & top. I reckon that a router will give me better finish, some detailing and square tenons (if I put a jig together first). The trouble is funds are quite limited.
The ryobi 1/4" is about at £49 or £89 with their router table.
My question is - is this good enough to give me a good quality result?
The view on here (I've searched a lot this week) - and from looking at cheap brands in the diy sheds - seems to be that nearly all sub-£50 powers tools are too low quality to do anything properly. Its not that they will wear out - they appear unable to cut straight from day one. Eg. I looked at a router and a crosscut mitre saw in Wickes and the router could not plunge if you pushed the wrong handle - it canted and bound on the pillars. The saw head could be rocked from side to side by several degrees depending on how you pulled on the handle. Clearly neither of those could be relied on for a good cut.
So are any of the cheaper power tool brands (from screwfix, etc) reliable OR does good woodwork have to wait until I can afford better - or cut straighter with a hand saw.
