MikeG.
We're narrowing in on this now! Pac has it, except that I would have an extra one in the middle.
Mike
Mike
Jake":1dvzw9kw said:How thick would you ideally want these screens to be, Lady?
Mike and PAC's ideas are best if you want them to look substantial.
If you would ideally have something thinner, then directly laminating layers of flexi ply/mdf would be better. Making the formers is no more complicated than making the curved frame pieces in the other version - probably less as you only cut one curve around which to bend the glue up, rather than two parallel curves to make each frame piece. The whole idea of the flexi stuff is that it will hold the curve once it is glued.
9fingers":27idgfgb said:Whereabouts are you based Lady?
Maybe a forum member can offer some help with your design?
Bob
PAC1":21t0u5p8 said:Ladyinthisdress.
If you are going to have curved pieces that are only 25mm wide I would not use MDF or Pine as both of these could snap under the force from the skin trying to straighten. I would only use birch faced ply.
PAC1":1nzutk8g said:With that shallow curve pine will be ok. make a cardboard template and try to match the curve and wood grain as much as possible. Avoid having the grain curving the opposite direction to your curve
