Karim Sleiman
New member
- Joined
- 20 Mar 2023
- Messages
- 4
- Reaction score
- 0
A dear friend has asked me for 6 Floating shelves 3 from black walnut and 3 from European oak she wants them to be from solid wood as thin as possible and to have the cathedral look rather than the rift or quarter sawn look. so.. I'm looking at Flat sawn wood size is 450mil in length by 150mil inches width as for thickness 20mm. Given that ill do all the necessary steps to prevent warping by milling both sides equally, letting the wood acclimate. my question is would adding a batten or a cleat to the underside of the wood be a good idea to prevent warping? even if its just one piece of wood. I have attached a picture for batten reference. i have read that usually you screw the middle of the batten without expansion slots and for the rest of the screws you should make a elongated slot for expansion and contraction. Since it will be a floating shelf hung with invisible floating shelf brackets How can i direct the movement away from the wall, Can i screw the batten without the expansion slot at the wall side and the 2 other screws will have expansion slots? i hope this makes sense! A pic for reference is attached.
