A
Anonymous
Guest
I came across this Dremel SCROLL STATION saw and the spec is good with a large cast iron table, 18 inch throat, worklight, fast tool-less blade changing and top-mounted controls etc.
Another very handy feature is the front-mounted tension lever which is a real time saver if you do a lot of internal cuts !
The bit that caught my eye though is the ability to turn the blade 90 degrees in the holders similar to the only other saw I know that does this, the Diamond.
I'd be interested to hear comments on this saw if anyone here uses one.
