edmund
Inlay questions for you all. I'm planning on doing some inlay work on my next project. The inlay will be into a solid substrate (i.e. not banding or stringing with veneer work). So,
1. Is there an ideal thickness or minimum thinness for the inlay?
2. I've seen marquetry supplier supply "square" lines. Where the line is say 3.4mm - does this mean 3.4mm by 3.4mm (sorry this may sound a bit dim)? Only reason I ask is that lines for stringing are typically stated to be about 1mm thick.
3. Presume you can always make it yourself.
Thanks in advance for your thoughts.
Edmund
Edmund
