Hello all, first post after lurking for some time.
After reading some great advice on here I've recently acquired an Inca 342 bandsaw. I managed to get a good price on it as the tension spring was missing. Basically the tension 'box' with the top wheel shaft and tracking adjuster is empty, the tension screw is present. I've printed out a copy of the manual with the parts diagram and can see a spring, tension indicator and spring 'cup' should be in there. So now I'm looking for some specs and advice on a suitable spring. Has anyone replaced or upgraded theirs? Does anyone have a photo/diagram of the inside of this assembly?
It's had a good clean, new wheel and guide bearings and I've placed an order with Ian at Tuffsaws for a set of blades. I may even post some photos. Really looking forward to getting it up and running again!
Any advice will be gratefully received.
Many thanks,
Carl
Many thanks,
Carl
