FrenchIan
As it says....
I have acquired several books (paperbacks) which are taller than normal, so don't fit my bookcase. There is plenty of space between the top/bottom edges of the book and the text, so I was thinking that I could cut maybe 1cm off the top and the bottom of the book....
I've tried it with a tablesaw before - not good. I've tried it freehand with a band saw - still not good - it ended up frilly. I'm thinking that if I made a simple clamp, to hold the book just behind the cut line, then fed it freehand past the blade....?
Any comments?
Any comments?
