woodfarmer
So far I have had zero luck making anything using cherry without it splitting catastrophically. Even just cutting out some blanks for making fruit. I have used diluted pva and neat pva to seal it. All to no avail except possibly one bit I cut as a small bowl blank, it has bent but not yet split. The reason I am asking is I may soon have the chance to get some green cherry wood. Should I plank it up into about three inch (75mm) thick planks and seal the ends. Or something else? ATM I store wood in a barn, in the summer with 30-35 C air temperatures it is only a bit cooler in the barn. I have another which is open fronted and damp so cooler. or should I construct something in a very shady (from trees) place. I do get the odd split with other woods but for some reason cherry is my nemesis.
