Neocleous
Hi all,
I have two pieces of laminated 18mm MDF making one 36mm piece and I have cut domino slots in the centre of each board, this is a centre self in a book case so I want the added safety of the double stack of domino's, also I'd like to know an accurate way to do this if there is one.
I tried this on a test piece and I was less than 0.5mm off but with a domino if it's not perfect vertically then it's just wrong. I measured 9mm left and right of a centre line and lined up the base plate marking on the side of the domino to the line but I was slightly off which isn't surprising with all the manual alignment.
Am I missing a trick with this?
