Can't see how angling the table will help - it's the same as rotating the piece surely? What you're aiming for is a way of holding the piece at a slight angle to the fence - not the blade.
For a long taper like that I would first rip a piece of mdf slightly longer than the cue (or portion of if you're making it in sections) and about 100-150mm wide. Then using a straightedge guide set at the required taper angle rout a groove close to the edge of your ripped piece for you blank to sit in, then add appropriate clamps to prevent it turning during the cut (which IMO it almost certainly will want to). Insert the blank into the groove/dado (it doesn't really matter what - it's just a slot of some sort to locate the blank) and run the whole caboodle through the bandsaw against the fence multiple times, rotating slightly between cuts.
