Sorry to keep going on but would you recommend the same procedure for, say, a simple square of plywood? i.e. draw it up with Autocad, take it to a printer, adjust the print out by 0.17%, mark it through with pinholes, etc.haggis999":3dcxxbpa said:As I mentioned in earlier posts, I was never happy with the idea of taping several A2 sheets together, as I viewed it as being the potential source of more problems. After reviewing my options, I decided to get a local print company to produce a full size A0 copy of my drawing, which turned out to be very slightly larger than full size. However, all the right angles were still right angles, so I reckoned that the drawing still retained the same proportions. The increase was just over 0.17%, which increased the longest diagonal by only 1.35mm.
That was close enough for my needs, so I have made a start on marking out the outline on my first shelf by making pin holes through the drawing. After drawing lines to join the dots, I will run various measurements to confirm that all is well. As my dad used to say, measure twice, cut once.
Are you suggesting that our OP should go the extra mile and invest in 5 axis CNC to solve this deeply puzzling problem? I expect it could sharpen pencils too!worn thumbs":3gq4of41 said:I am mystified by the amount of comment this topic has generated.In the OP I see only straight lines and with the use of a basic CAD program it should be possible to determine the distance from any relevant feature to any other feature and strike arcs to accurately locate the points at the end of each line.A good rule and a straight edge should have the job done in a few minutes.
While I can do the marking out with basic tools,I have to say Jacob is mired in the past with reference to drawing boards and their attendant kit.Too slow and too hard to modify.A company I worked for in the nineties gave their drawing boards away as they had been well and truly superseded by 2D CAD and a few months later they moved into the realms of 3D modelling and 5 axis CNC......
You make a very convincing argument for using a bottom bearing cutter. That's just the sort of practical advice I was seeking.worn thumbs":2aqqm5ya said:As far as the discussion regarding router cutters is concerned,I have always held the belief that a bottom bearing cutter is inherently more reliable for accuracy than a top bearing cutter.Mainly because if you hiccup or otherwise twitch with a top bearing cutter,there is a good chance that the router will rock and take a bite out of the workpiece.With a bottom bearing,you may leave a bump that can be removed with another pass.The same template will serve if you position it on the relevant surface.
My ELU MOF96E router only takes bits with shanks up to 8mm diameter, so that eye-wateringly expensive item was never an option!Racers":3hmzhb8g said:It does look nice that Wealden cutter, I take it you don't fancy the diamond cutter one!
Sorry I was a bit mystified - I didn't realise you were so bereft of basic drawing skills. But I don't think I was the only one suggesting using a pencil.haggis999":38xax777 said:I am bemused as to why Jacob and Sgian Dubh are perpetuating an irrelevant discussion about how I should have designed my shelf, as my OP made it clear that my design was already completed before I started this thread! Jacob made a useful suggestion on how to transfer my design to the wood surface, but he only came up this idea after I had embarked on my 'prick through a print' solution (which just happens to be the method proposed by Harbo, the first person to provide an answer to my question). If Jacob had made that suggestion two days ago I would probably have taken his advice instead.
Racers":1ahov8kb said:I think it's good that hagis999 has stuck around most people would have probably not come back.
Jesus Jacob. The Charm School. Did you sue them? :?Jacob":2z4yw2eg said:Sorry I was a bit mystified - I didn't realise you were so bereft of basic drawing skills.
Because I keep trying to explain to him how to do it (just draw it with a pencil, ruler, set square etc) but he argues about it! :lol:Bm101":12wp704t said:Jesus Jacob. The Charm School. Did you sue them? :?Jacob":12wp704t said:Sorry I was a bit mystified - I didn't realise you were so bereft of basic drawing skills.
From memory it was a fella called Francis Bacon who likened knowledge to two types, The bee and the spider. One type keeps buzzin' about, pollinating flowers, the other makes webs.
Don't doubt your knowledge for a second but come on. Op has been clear he is not a seasoned woodworker. Why keep battering the fella? Common courtesy costs nowt........l
