Hinge search
DavidRa
25 Oct 2020
Gerrards Cross
I have been asked to make a foldaway extension , in wood, to fit under the 15cm overhang on a marble topped kitchen island. The extension will be 45cm wide and will fold vertically under the overhang. When horizontal it will extend the worktop by 30cm.
I know I can make it such that the extension when horizontal is flush to the underside of the marble top but is there a “lift up” hinge which will make the extension flush with the top of the marble island. Just to be clear the extension will move 90 degrees from vertical to horizontal . The hinge cannot be screwed directly into the underside of the marble but can be screwed into the wooden base unit.
Any help would be appreciated
Regards
David Rankin
m. 07771 956711
Sent whilst on the move
provided the top is not 50mm thick "read v heavy" I would undercut the marble like fitting a hinge to a door.... and use an epoxy glue.....
best find a hinge with large /long wings....a normal butt hinge won't do.....best use st/steel as brass will stain the marble green....
epoxy will be stronger than the stone...
marble is easy to work.......even with a Dremel.....
