filsgreen
I've been trying to get the infeed/outfeed tables level with the cutting bed of my Axminster thicknesser. Unfortunately the in and outfeed tables are about 2mm lower than the cutting bed, however the rollers on the tables are at the same level, is this correct?
Here is a picture of a level spanning the cutting bed and the in feed table roller
As you can see, the infeed table is at an angle and there is a lip to the cutting bed, it is the same on both sides. I phoned Axminster and they referred me to the levelling nut that project from the machine which affect the angle of the tables . Are there any adjustments where I can raise the level of the in/outfeed tables to the cutting bed?
Any help will be much appreciated
Phil[/img]
![ee04ff14.jpg](https://proxy.imagearchive.com/fdd/fdd9f2c0e2b25f27af43b83007a5be8e.jpg)
Phil[/img]
