This is a serious post.
I was reading an article on snipe and how to overcome the problem and it got me thinking. If we take a planner/jointer the out-feed table in theory should be level with the cutting blades when they are at top dead centre however we normally set the blades a fraction higher. Therefore if we lower the in-feed table by say 1 mm, 1 mm should be taken of the stock and the planed face should rest on the out feed table as the stock passes over the cutter. The same applies to a router table if the stock has to be planed eg the out-feed fence is shimmed out by the depth of cut required and made level with the cutter. Also the same applies to power planes the in-feed sole (the part in front of the rotating cuters) is raised to the required depth of cut and the out-feed (the sole behind the cutters) remains level with the blades. What has this to do with snipe well it does have an effect but it got me thinking of something far more interesting, please read on.
If all the above is true, how does a normal hand plane work? we know it does but how. The sole of the plane is fixed over its length and the blade projects to set the depth of cut. So into the workshop I go, I rub some engineers blue over the length of the sole, set the depth of cut to about 1mm, put some soft wood in the vice, applied downward pressure to the front of the plane, pushed forwards about 100mm then stopped, removed the plane and guess what, the sole of the plane behind the blade had not been touched. Repeated several times keeping downward pressure on the front of the plane same result. Then I relaxed the front pressure and operated the plane normally moving the downward pressure to the rear at the end of the stroke, only the very back of the sole near the handle had made contact. This indicates to me that the plane is operating at an angle eg both parts of the sole can never all be in contact with the wood. Anyway I can still plane quite flat but I am now confused about the physics and why we spend so much time making the whole sole flat.
