I would be very grateful if anyone can suggest a method of retro fitting aquamac 21 door seal to an existing wooden door frame without taking it out? The door frame has no recess for any seal at the moment. The biggest problem is that it does not have a wood cill and the door frame is tight into a recess on both sides. I cannot get a router into the recess to use a router bit and if I could I could not run it to the bottom edge of each jamb?.?
Completely flumexed!
