According to your bio page, you live in Hungary? If so, youre only going to get a month or two's use per year, unless youre a cold water fiord swimming person. I would seriously reconsider.
I dont have solar electric, at my time of life I would never recoup the costs of install.
A solar pump here is over 2,000 euros, panels extra.
To get clear water the pump needs to run 10 hours a day every day the water temp is over 20c, and less hours a day as the water gets colder. By the time its down to 10c, the pump can be turned off although I run it an hour a day just to keep the filter material alive.
I dont know what your panels produce, but you will need at least a 0.75KW (equivalent) pump for an 8 x 4 x 1.4 deep metre pool.
Chemicals needed depend on the pool. Starting from scratch I seriously recommend a salt water pool. A bit more start up cost but greatly reduced maintenance.
A fresh water pool needs Chlorine, and PH adjuster (up and down) all depending on temperature, original water composition, and usage, so its impossible to advise you on quantities of each.
Then you need algicide, flocculent, tile (or liner) cleaner on a regular basis.
If you are that far north you need to invest in a very good cover and a pool heater to stop the water freezing. When water freezes it exerts HUGE sideways pressure, and can easily crack a concrete side wall.
Its truly a non stop job keeping a pool in good condition. When we moved here we couldnt understand why the Cypriots dont have pools. 11 years on, I know exactly why. :roll:
8) 8)
