Be wary though because so many panels are bigger than stated - ie you may order 6mm but they might send 6.25 instead.
I have 3 two flute straight cutters from Wealden at 6, 6.4 and 7mm. I find that on larger panels especially in birch ply, 6.4mm doesn't give enough wiggle room and its a real bore if you are using glue. DAMHIKT!
You will really struggle using the router handheld with those Rutland cutters. Aside from the danger, it'll be really easy to introduce a tilt which will knacker the groove. You could use straight cutters and two fences, but its awkward. It may well be time to invest in a table - you don't have to spend a fortune and its not so tricky to make your own.
Tim
