Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
I blame Wuffles!*
I'm trying to make a new removable shaft+handwheel for the tensioner at the top of my bandsaw.
It's a sloppy 12mm i.d., socket with a notch in the ring surrounding it. It's supposed to take a 12mm shaft with two diametrically opposite keys (I'm guessing this). Presently there is a T-shaped bit of flat bar that goes into the central hole with a wooden handwheel glued on, but it's really uncomfortable to use. It was made by the last owner, and he did it well, but my hands are bad and I need something easier to turn.
My idea is to use a 12mm bolt, threaded to M5 diametrically, with a bit of studding glued or peened into place to make the two keys. An M12 bolt fits one of Axminster's replacement handwheels nicely, and the combination would do the job really well, I think.
I have a leftover box of BZP 12mm Grade 8.8 high-tensile bolts of suitable length. I found a chart on the web that says this:
Can I drill it and tap it fairly easily? I'm sure it will cut with a hacksaw, and can be filed without problems as I've done this before with bolts from the same box. I only have HSS taps and drills but I also have cutting/tapping compound and know how to hand-tap steel (or worst-case do it in the pillar drill with the belts removed).
Should I try to anneal it beforehand? Worth the effort?
It's a very low strength application, so if I do soften the steel it probably won't matter.
Thoughts appreciated.
E.
*I should explain - he's had problems with his BS tensioner, and talking to him the other day reminded me I should get my finger out to sort out my own one!
Class 8.8:
Proof strength: 660 (MPa),
Yield strength: 640,
Tensile strength: 800
Medium carbon steel; quenched and tempered
E.
