Good quality hide glue
Noho12C
18 Jul 2016
Stafford
Im trying to use more hide glue in my projects but struggling to find good quality one in UK. Bjorn and Tools for working wood sell good hide glue, but import from US is quite expensive. I can find easily Liberon pearl glue, but it is mostly bone glue, much more smelly.
Anyone has a good provider of good quality hide glue ?
profchris
14 Jun 2015
Suffolk
Luthier supplies are your answer, something like this:
(I've not bought from them, but you could email queries about the smelliness)
I use ordinary pearl glue for my instrument making and put up with the smell. I can get invisible glue lines joining tops and backs with that, so I've never bothered lashing out on the more refined stuff.
Just4Fun
21 Sep 2017
Finland
When does it smell? At what point in the process?
I used hide glue for the first time in the past week. Mine didn't smell, or at least not a great deal. Any glue smells a bit but the hide glue smell was not really noticable. Was I just lucky? Or have I lost my sense of smell? (Isn't that a symptom of covid? Perhaps I should be worried!)
stuckinthemud
17 Jun 2019
Caerphilly
I make my own from gelatine powder, the stuff for making jams and jelly. Mix with a little water. Makes very high grade glue. The glue should NOT smell.
profchris
14 Jun 2015
Suffolk
If you heat it, glue and then turn the heat off there's not much smell. If the glue pot is warm all day ...
Food gelatin works, but is really high gram strength so it gels almost immediately. You have to get the joint really warm to use it successfully.
Lower gram strength HHG gives you a minute or two to assemble the joint, more if you warm it.
Noho12C
18 Jul 2016
Stafford
Thanks, for the luthier hide glue, I've seen it, but worry that the 444 is a tad too strong.
I bought some urea to make liquid hide glue. HHG Is nice but sets too quickly for me. Doesnt give much time to fiddle with your joints. Though used HHG for rub joints and has been great.
Noho12C
18 Jul 2016
Stafford
Good quality hide glue doesn't smell at all. And it is made from hides and sinuses.
Pearl glue is mostly made from bones (sometimes called bone glue) and stinks.
It depends what you're using.
I used Luberon pearl glue in the past with good results, but 1/ stinks and 2/ didn't manage to make good liquid hide glue.
Seems that hide glue is hard to find in the UK :(
Noho12C
18 Jul 2016
Stafford
I used it also, and worked well. Just received some old brown glue, havent used it yet.
But feel like experimenting a bit 😃
Argus
21 Oct 2002
Wood-work classes in school - late 1950's - was always accompanied by the pervading ronk of glue boiling away in the background.
I suppose that it must have been the cheap old bone-stuff they used.
Then there was the big glass cabinet behind the teacher's desk with the shiny new plough-planes and other stuff that never got used.
Still, a few years later PVA came along and that's what most of us now use, along with all the other glues. No pongs at all. Having said that, on the rare occasions that I need something remotely 'organic,' I get a bottle of Titebond.
The shiny planes are now on Ebay, it seems.
Droogs
Is that chisel shar ... Ow
14 Mar 2013
Edinburgh
If you have hide glue of any type (Cow, Sheep, Fish, Rabbit etc) and it smells once heated; then the glue is blown. It has been attacked by the yeasts and bacteria around it and is really no longer usable. Once a hide glue starts to smell it will quickly lose its ability to act as a strong glue. An old trick to try and extend the life of the glue was to add in a quart of vinegar to the smelly mix and simmer it away and this would hopefully kill the bacteria. But as i said, if it smells once soaked and heated then ditch the glue you have and get new. If it is a new purchase then you have been sent old stock that has been on the shelf for a while or stored in a dampish environment.
hth
Exluthier
3 Aug 2018
Bedford
The reason that brown Titebond doesn't set in the bottle once opened is that it contains a chemical additive designed to prevent setting. It may be more reliable now, but then (some 20 years ago) I had the embarrassment of a violin fingerboard which I'd glued down with brown Titebond simply detaching itself from the instrument.
JohnPW
5 Jun 2013
London
I found this from a search:
It claims:
"La Colle is a superior glue of higher quality than commonly sold hide glue, pearl glue or bone glue. This high-grade protein glue is a mix of various grades of hide glues and bone glues that have been carefully selected for their excellent quality, strength and flexibility. It is free from additives. This unique glue is the fruit of years of research and testing by craftsmen, restorers, conservators and scientists. La Colle is a marriage of traditional materials and techniques refined using the latest hydrolysis technology together with Yannick Chastang’s understanding of what makes perfect glue."
I don't know if it smells.
But all the hide glue I've used for instruments at college and at 2 work places did smell, no it wasn't mouldy. I'm not sure where the glue came from, possibly Liberon Pearl glue. One glue when mixed was colourless not light brown, that could be rabbit skin glue but that's just a guess
I'm used to it and don't really notice the smell anymore. Dried hide glue has an indefinite shelf life, obviously if kept dry.
Another one:
Droogs
14 Mar 2013
Edinburgh
Yannick is a master eboniste and is known for spending a lot of time investigating hide glue and its formulation for many years.. He did a bench talk about it not that long ago on benchtalk101
Noho12C
18 Jul 2016
Stafford
I've seen this glue already, but it says you have to mix the whole batch at once. Though I guess the extra can be frozen for later.
