SlowSteve
Hello.
Would anyone be able to point me in the direction of a source of good enough straight 1/2" router bits - the really long ones - Ideally 65mm?
The kitchen fitters use them a lot, and I am finding that they are an all around amazing DIY tool - everything from fitting worktops to milling the tops of doors without having to do a contortionist act with a plane - anything that needs a dead straight line with a good finish, but I am am using Screwfix straight fluted ones at the moment and they really don't last very long and are a pain to plunge. I have seen a lot of Youtubers using spiral shanked bits, which by the look of them are cobalt but can't seem to find them anywhere.
If the Cobalt ones are ferocious in price, then I'd be more than happy to settle for some cheap-ish spiral bits that you chaps reccomend and consider the semi-disposable - it would be great if you could point out some good sources, and also what I should be searching for0.
Otherwise, if there are other makes which you think give significantly longer life and think they are worth the money, I'd like to hear about those as well.
Steve
Steve
