trevtheturner
Hi All,
I am currently refurbishing our utility room and am installing a worktop, just under 3m long, along one wall. Worktops from the sheds only seem to come 600mm wide, with 'breakfast bars' available to order at 900mm wide but only up to 2 m long. I want a top 700mm wide.
Bought a standard 28mm worktop, have trimmed off the post-formed edge, and biscuit-jointed pine along its length to provide the necessary width. I now want to cover it (it will be installed upside down, to provide a better glueing surface?) with oak boards. This comes from my stock, bought at Ledbury auction last January, which I have resawn to 13mm and then thicknessed to 10mm. With care I can join all the boards with biscuits. When the top is covered the front edge will be finished with a 10mm thick oak lipping. Expansion gap around the walls, 10mm, will be filled with silicone sealant, the wall tiles will be set 3mm above the finished height of the top and this gap will be filled with silicone rather than grout.
The question is: what adhesive do I use to fix the oak boards to the worktop?
I normally use PVA for wood, but this needs clamping. Have considered using a polyurethane, e.g. one of the Titebond range, but again this needs clamping. I can't do this because of the width involved, so would weights on top provide sufficient force until the glue is cured. Alternatively my thoughts are turning towards using a contact adhesive of the Evo-Stik type. I can do the assembly, preferably in situ, but could do it on the bench if necessary. Would prefer to do it in situ because of the finished weight.
Any thoughts and suggestions will be welcome.
(Clamping the lipping will not be a problem, but I will probably have to buy some of those nice Bessey edge clamps to do it! :roll: )
Cheers,
Trev.
Cheers,
Trev.
