Giff
A bit of a random question. I use a Vac Bag and have good results. Even very tight formed curves over a Poly Former. The question is how does an "air drying" glue work without air ? I use a D4 waterproof PVA type and haven't had problems, but I have just laminated a large batch of 3mm veneers on to ply and notice the glue has not gone off when it comes out of the press and is lifting at the corners on some panels. How is it supposed to work without any air to cure it ? Probably a simple answer but I would be grateful for an explanation. Thanks Geoff
