glue heater
GEPPETTO
26 Oct 2004
Vinci (FI) - Italy
Hi all,
I have to use hide glue to veneering. I have read that temperature does not have to rise over 60-65 Celsius degrees because at that point the glue loses its features.
I have an electric burner without regulation and I thought to equip the burner with a thermal regulator which turns off the voltage at the right temperature.
But I have some questions: Can I put the regulator attached at the water container where the water will have the same temperature of the glue or I use a regulator with far probe and put the probe into the hot glue?
Please help me, I want to buy the regulator this evening
Thanks in advance
A
Anonymous
Guest
Geppeto
I would get a regulator that can be submersed in the glue
