Garage workshop
saleemtaibjee
13 Nov 2022
Dorchester
Hi. We are planning a new garage which will be partly for woodwork, also for general storage, bikes, etc. Any advice on partitioning or screens to avoid wood dust getting everywhere?
I simply used CLS and 9mm ply.
Stupidly I put the cls on the woodworking side and it collects dust!
I found a couple of internal doors for free to link them.
I did the same as Jameshow, but I boarded both sides. The back 2/3 of the garage is for woodwork, front 1/3 utility room for freezers, tumble dryer (condensing so it doesn't affect the wood much) and storage. Used a spare internal door i had to connect both. Make sure the door is big enough to accommodate the biggest thing your ever likely to make :)
Stud frame is simply screwed into the brick walls, so if it ever needs to come down, it won't take much effort.
I also boarded out the ceiling - T&G pine for this. Insulated all round and it rarely drops below 2c regardless of outside temps.
Oh and the best thing I did was swap the up and over door for two Barn style doors. The track for the U/O door used to protrude through the stud wall. You can see the patch up job i did on the mdf - not pretty but functional.
As there is no natural light in there, i have 4 led daylight lights - works a treat.
