Pablo_WildWood
New member
Hello everyone,
I have a pretty exciting shop ahead of me, I have recently started a business, and have managed to gain investment of £7.5k from the Princes Trust to pursue my goal of being a self employed wooden creator - a lot of hard work has gone into the planning side of things, and I am very nearly ready to go into production, but obviously I need to make sure I have all the right tools!
I have a few questions, and hopefully with all of your helpful advice I can choose the best tools for what I need to do. My business is called Wild Wood, and I plan to make wooden clocks from cross sections of logs, upcycled pallet furniture, and some wooden jewellery. I will be using a laser cutter to etch in digital designs onto my products. I have an extensive list of tools that I have shopped around for, but as a relatively inexperienced wood worker, I am not 100% sure that I have the right tools for the jobs (I am pretty sure I do as I have a carpenter friend who has been helping me, but I am looking for second, third, and fourth opinions).
Initially I plan to buy about two thirds of the things on my list, what I am looking for from you guys is confirmation / dispute over whether I have got A) The right tool for the job B) The best tool for the money I am spending. I tried to post links but I was not allowed so please if you can google the tools as I listed them you will see what I am looking at, thankyou![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Any advice or information greatfully recieved, heres the list!
Reciprocating Saw - To break down pallets - MAKITA DJR181Z 18V LXT RECIPROCATING SAW BARE
Bosch Mitre Chopsaw - willing to potentially spend a bit more on this but a friend recommended the Bosch range which was cheaper than the makita one I originally had on the list - suggestions especially welcome about this - BOSCH GCM 8 SJL 216MM 8" 1600W PROFESSIONAL SLIDING MITRE SAW
Festool Tracksaw - Festool Circular Plunge saw TS 55 REBQ-Plus-FS GB 240V with 1 Rail
Workmate for securing workpieces - Black & Decker Workmate Dual Height Work Bench.
Makita Drill set -MAKITA DLX2007MJ 18V BRUSHLESS IMPACT DRIVER/COMBI DRILL KIT INC 2X 4AH BATTS IN MAKPAC CASE
Router - mainly for cutting in clock mechanisms but plan to use for all manner of things - MAKITA RP1801XK 1/2" PLUNGE ROUTER & FINE ADJUSTMENT GUIDE IN HEAVY DUTY CARRY CASE
ROS - I will be using this for finishing my clocks (and everything else) - very important that I get a good one so again keen for feedback on this, did i choose the best brand for the money? MAKITA BO5041 125MM RANDOM ORBIT SANDER WITH ESC & FRONT GRIP
Selection of different bit boxes (3 items here) I have included the product code so you can just search on screwfix for each item;
WOOD DRILL BIT SET 35 PC (75037)
MAKITA ACCESSORY KIT 252 PIECE SET (90001)
COMBINATION DRILL BIT KIT 160 PIECE SET (88149)
Dremell for detail -DREMEL 8200-20 10.8V 2.0AH LI-ION CORDLESS ROTARY MULTI-TOOL (6407G)
Pocket hole tool - Do I need this? Looks great and I would definitely use it but is there a cheaper / better way to achieve the same result? I was planning on getting a pillar drill so maybe I could is that to do this? (Ebay) - Kreg R3 Jig Junior Pocket Hole Wood Joinery Kit Woodwork Joint Carpentry Tools
Full selection of screws - can anyone recommend a better supplier for screws / would slightly cheaper ones suffice? I have used turbo gold regularly on site so I went with what I know but is it necessary? GOLDSCREW WOODSCREWS EXPERT TRADE CASE DOUBLE COUNTERSUNK 2800 PCS (44480)
Planer / Thicknesser - I expect to be using this ALOT, planing full wood rounds and pallet wood mainly - Record Power PT260 Planer Thicknesser
Biscuit Joiner - for furniture construction, is this a decent one? Makita BPJ180Z 18v LXT Biscuit Jointer (Body Only)
Decent wood glue - Titebond II Premium Wood Glue - 470ml
Good set of chisels - (UK Tool centre) - Stanley Dynagrip Chisel + Strike Cap 5 Piece Set + Access
Palm Sander for final finish sanding - MAKITA BO4555 HOOK & LOOP / CLAMP FINISHING PALM SANDER INC DUSTBAG
Pallet Breaker - Roughneck Demolition & Lifting Bar 94cm (37in)
Dust Extraction - SCHEPPACH HA1600 1150M³/HR DUST EXTRACTOR 230V (65112) - Screwfix
Osmo - for finishing, also considering buying danish oil and beeswax as sometimes I will want variation in the finishes, can anyone recommend me what is best for what? - Osmo Polyx Oil Raw (3044)
Dustmask and goggles - JSP FILTERSPEC PRO VALVED RESPIRATOR BLACK P3 (1785G)
Items that I am considering but won't necessarily buy straight away;
Pillar Drill - I know this will be useful, but do I need it is what I am asking myself.... Record Power DP16B Bench Drill With Cast Iron Handwheel (My Tool Shed)
Band Saw - Again same as pillar drill, I know I would use this, but how much? some information about the most regular applications for this tool are welcome, it could be that it will be in use all of the time if I get it but Im not too sure! SCHEPPACH HBS300 300MM BANDSAW 240V (9424F) - Screwfix
Thanks everyone in advance, looking forward to all your feedback,
