wizer":3gpkso1j said:There. I said something nice about Rutlands.
BradNaylor":7u7tzgjp said:I had the same table but mine was badged Ryobi.
I never got on with it. I didn't like the fence and the sliding table is a waste of time. What's the point?
I reckon this design is bloody dangerous, too. You are encouraged to lift up a heavy cast iron table to facilitate cutter changes. One slip and the whole thing could come crashing down and slice a finger off.
In the end I left mine behind when I moved workshop a couple of years ago. Much better IMO to build your own.
Welcome back by the way, Matt. Where the hell have you been? Any chance of you making it down to JonnyD's bash next month?
Brad
(I was probably still Dan last time we spoke! :lol: )
dickm":349leq38 said:I've got the Ryobi too, but it's an oldish one and certainly doesn't have the gas struts - if anyone has one with them and can give me the spec of the struts, I'd be interested.
BradNaylor":1t6365ci said:I had the same table but mine was badged Ryobi.
Brad
B****r. Why did I not think of that?ike":2ode2e22 said:PS, I've never needed to lift the table once since I started using it. To change a cutter - just slide the table right to one side. :wink:
dickm":2n7xyhc6 said:B****r. Why did I not think of that?ike":2n7xyhc6 said:PS, I've never needed to lift the table once since I started using it. To change a cutter - just slide the table right to one side. :wink:
And w.r.t. the hatchback struts, I'd been thinking along those lines exactly. Any suggestions as to what size might be needed? Mini or 4x4?
studders":27o9qlwn said:dickm":27o9qlwn said:B****r. Why did I not think of that?ike":27o9qlwn said:PS, I've never needed to lift the table once since I started using it. To change a cutter - just slide the table right to one side. :wink:
Something like a pair of Fiesta ones should do it. If you look around the breakers yard you should find some where the mountings just unscrew/unbolt, saves having to faff about when it comes to mounting them on your table. Don't do what I did and just 'ping' one end off from inside the car, it shot open and nearly took me bleedin teeth out. :shock:
Chems":31jdtmgk said:What you need to do is look at either end and there are little clips you can ply off with a flat head screw driver, then they will come out nice an easy thats how we are taught to do it an I've done it a few times on jobs and its very simple for anyone with a bit of a technical figure it out mind. Do be careful thou as you've been warned twice!
dickm":1gbp0tzl said:Chems":1gbp0tzl said:What you need to do is look at either end and there are little clips you can ply off with a flat head screw driver, then they will come out nice an easy thats how we are taught to do it an I've done it a few times on jobs and its very simple for anyone with a bit of a technical figure it out mind. Do be careful thou as you've been warned twice!
Thanks for the warning(s). I'll take my face shieldBut when you say "little clips" do you mean the ones that hold the strut to the pivots at each end, or something that holds the piston in?
