Foot Switch for £4
thirsty
2 Jan 2012
Hull E.Yorks
Hi every one my first post a friend sold me this old Delter scroll saw and I have been really enjoying learning a new woodworking experience
There's been lots of talk about foot switches on here so I thought I would show you the one I made for a bout £4.
The switch is from MAPLINS and is a pressure switch not on/off switch I used some scrap wood a bit of gafer tape and it works really well. In the past I have made all kinds of jigs etc for use in my old workshop just love the challange not to buy if I make it.
    204 KB
    166.4 KB
    233.7 KB
Welcome, Thirsty.
You know what they say, if it can’t be fixed with gafer/duct tape then it is not reparable/fixable. (hammer)
Take care and enjoy your scroll sawing, warning it is addictive. :shock:
Chris R.
sry dont know the code just went into the shop looked at the switches but I will have a look on the site to see if I can find it and post the code
The switch I used was Push-to-make switch code N92AP @ £3.99 its a 2 pole connector so use it with a break in the negative wire
Hello Baldhead . Have a look at my posting of about a year ago , I made a switch for my delta , wouldn't be without it
look at scroller Franks postings Dec 14 2012 somewhere I have a picture ! but I cant find it !!! ------------- not a lot of good then eh Frank ! ----
hope this helps ----------------Frank------------------
I like the idea of cheap stuff, but for 12 quid I think I prefer my chunky cast alloy footswitch that will survive when, not if, I drop something on it. Having said that, that switch does looks quite robust and I'd have definitely considered your way if I was needing one now.
Martin.
Negative wire :?: :?:
AC supply correct term is (Neutral) & (Live).
If using a single pole switch, ensure you break/switch, the live supply/wire.
A two pole switch should be used on machine type equipment, if possible.
Please read this as help and not as criticism, it is not intended.
Chris R.
It's only single pole according to the website :?
thanks for your input re switch I fitted it about 3 months ago and it works for me bit of a bodge buts thats me a 63yrs old senile fart lol
